Bravo 3 to bravo 1 conversion.
there is no fuel pressure codes for a STOCK OEM 496
There is no cool fuel codes either but there is water pressure and that parameter and fault code(s)
I have all the scan tools and all the stuff to even test the PCM and the injectors along with fixing any of that if need to be as well.
As stated earlier if you are in Texas BUP is THE man to go to PERIOD. I'm out of state (Oregon) and have used him myself. He has helped me tremendously and went above and beyond to get me and my family back on the water a few times. Very honest and cool guy and great to work with on all levels. I highly recommend him especially if you are in Texas you are lucky!
Again, thanks to this great community!
-j
Thank you. I sold the boat. Its out in Lake Cumberland now blowing rooster tails. I wouldn't put any extra money into those 496's. Just get them running better as is. Sounds like you might have a fuel problem. There is an anti siphon valve at the top of the fuel tank connected to the ball valve. Mine were clogged and i just removed them. Check fuel filters and Fuel injectors. Send the injectors out to be cleaned. Check and make sure your drives are trimming in and out properly. Does your exhaust exit through the side of the boat through an integrated muffler built into the boat or is it through the drive? could be exhaust restriction
As for the 496's, I dont want to throw any real money at them except to get them running as best as possible for stock. I can save my pennies for a repower that way.
Thanks to everyone's kind and helpful posts!
-j
Since you have the Muffler box through the side of the boat id say your fine there. Most likely take off those siphon valves and check to make sure both fuel pumps are working properly. High and low pump on that cool fuel set up. Also pull those injectors and have them cleaned.
The rain really for the past 2 months has basically stopped many boaters in the area, but for some it has been a break for them to bring their boats in and get serviced and or ahead on the maintenance. Anyways you have my info.
It would be good if you gave me your ENGINE SERIAL numbers so I can look up the past history and anything outstanding with recalls , service bulletins, warranty claims and so forth. You can OSO PM me those if you wish. THANKS
I have a 1996 Wellcraft Scarab P-29, and BUP was able to diagnose some engine issues due to dirty/darn near clogged fuel injectors as well as bad fuel lines and particles in the gas tank. It is actually all linked to each other.
I didn't realize the shelf life of fuel lines, but if your fuel lines are stock from 02, then you are probably pushing fuel line rubber particles directly into your fuel injectors which is causing those to clog and result in some power loss. If there are any particles in your gas tank from the 16 years of use on that boat, then those are clogging your injectors as well.
Once again, I cannot stress how important it is to listen to BUP. I am outside of Chicago, and he (being in Texas) is my #1 go to guy. It is pretty dang difficult to find anyone that you can trust in the marine industry anymore. He will save you money in the long run.
Thanks!
-j
