Serpentine Pulleys
I am trying to convert from V-pulleys to serpentine-pulleys without changing brackets. Is this possible? Power is mid nineties Marine Power 502s with crank driven raw water pump.
I found that March Performance can help me with the starboard engine, but not the Port since it has P/S. They only offer that option (double crank pulley) for a long water pump. Any ideas?
What I need:
Port Engine – Double serpentine crank pulley, a single water pump pulley, alternator pulley, and single press on P/S pulley.
Starboard Engine – Single serpentine crank pulley, single water pump pulley, and alternator pulley.
I don’t understand why March Performance doesn’t offer the double crank pulley for the short water pump application, but that is what they just told me on the phone.
I use this boat a lot, and am trying to eliminate the constant headaches I seem to get with V belts. I’m trying to avoid installing a “kit” with brackets, tensioners etc.
Any leads or alternate routes would be appreciated!
Steve
What I need:
Steve
