Bravo one cracked blade.
Here's my 3-blade Bravo 1 from the Talon.... It was labbed, and that is behind 680HP.. The prop lasted about 5 years before it thru the blade....
Everything is for sale @ a certain $$
Local guy has a 2008 35ft Donzi ZR with 496 HO.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
[email protected]
302-521-0123
I’ve never had a problem with cracked or throwing blades. I’ve been running the same labbed 30 bravo for about 12 years now with 825hp. May just be luck of the draw with the casting process.
I have a Q4x I run on my boat a lot. It’s got a little less slip than a bravo one and handles about the same.
When testing props I was comparing a 30p lab bravo to a 28p Q4x. The Q4x was a couple mph faster in the cruise speed and ran the same top end speed and rpm as the 30 lab. Based on that, if you’re running 28 non-lab bravo ones and you’re happy with the WOT RPM, I’d probably run 28p Q4x.
