MTI 340X Showdown—300R Versus 400R >
MTI 340X Showdown?300R Versus 400R
Old 02-23-2019 | 08:15 AM
Originally Posted by mikesufka
Will be interesting to see the 300R’s strapped to a 28 Skater ...
MDS
Especially the new widened 28 Skater that's being rigged now
lake p.a.l. is offline
Old 03-01-2019 | 07:40 AM
Originally Posted by X-rated
So.......After reading this, is it fair to assume that we who have been waiting for Mercury to roll out a new 450 or 500R will be disappointed when we only see a couple of mph gain and barely a second better midrange number over the venerable 400????
If the boat went from 113 and 123 with 300’s and 400’s, respectively, wouldn’t it stand to reason that an outboard 34’ boat with 500’s would run over 130?
engineermike is offline
Old 03-01-2019 | 02:40 PM
Jason did you happen to record fuel consumption at any of the speeds mentioned? "Another interesting comparison, the 300R model cruised at 59 mph at 4,000 rpm while the 400R boat was running 54 mph at the same rpm."
I would expect the 300 boat to be better just being lighter, the reports are these motors are even better on fuel than the Verados.
pstorti is offline
Old 03-01-2019 | 05:10 PM
Very interesting to read that the 400R rig outran the 300R in acceleration, as well as 10mph on top end. Everybody has been talking about how strong the 300Rs are in the low and midrange, I'm surprised they got pulled by the 400Rs there. For those of you discussing the lightweight tie-bar setup, I had Hardin Marine/CP Performance build me a titanium tie-bar for my 30 when we converted it to the 400Rs. It's half the weight of stainless steel, with all the strength and corrosion resistance. Give Mike Mays a call at CP Performance and he can build you one!
Skater30 is offline
Old 03-01-2019 | 05:49 PM
Originally Posted by larslindroth
Weight is a big deal and when you can save up to 300 lbs at the transom by going twin 300R's it's an attractive proposition for the smaller boats. The service cost, reliability, and noise levels are of course other factors that might be of difference. Once the Nordic 28SS with twin 300R's gets dialed in, it will be interesting to see if the performance difference won't be a lot narrower than the same comparison on the MTI 340X.
Photos and videos courtesy by way of Nordic Boats and #RiverDavesPlace forum, 28SS twin 300R and the bottom videos courtesy of Paul Wallner, Nordic 28SS 400R.
https://www.youtube.com/watch?v=4ekMeiL4umk
https://www.youtube.com/watch?v=op0IYU5SKT8
https://www.youtube.com/watch?v=WzTLnVclcF4
https://www.youtube.com/watch?v=s8f6prWWgeA
This is one of the few boats I would send the Fountain down the road for.
RaggedEdge is offline
Old 03-01-2019 | 08:21 PM
Dale, I am not suprised. The 300r with a 6400 max rpm would require a big prop to pull the big number on the upper end compared to the 400r with 100 more ponies and a 7000rpm max. This is only true with boats that are capable of running big numbers. A slower heavier hull I think would play into the torque of the 300r more. IMO for the cat boats that engine would be a lot better with a 6600-6800 max rpm. It would really help the acceleration. That is what makes the 300x so versatile.
Double Rigged is offline
