aeroquip and fragola have what you want , or send it to mark
Think I found it....
Fragola Performance Systems Flare Caps 492928-BL |
Yup, good find.
Originally Posted by phragle
(Post 4682010)
Originally Posted by Mbam
(Post 4682023)
I'm off the hook
:ernaehrung004:Well shoot! Guess I better find senders for water pressure and boost. I have poly lines running to the helm for both these gauges. |
Get a local hose company make you some nice high pressure lines.
Originally Posted by jamontes
(Post 4682085)
(Post 4682085)
Run an isolator for a mechanical gage so fuel isn't plumbed under the dash/helm.
Leaking boost pressure or water isn't as dangerous or flamable as fuel is. https://www.summitracing.com/parts/atm-5282/overview/ https://www.autometer.com/high-press...r-300-psi.html Instructions This isolator is installed in the pressure line between the carb or fuel pump (where you normally pick up fuel pressure) and the fuel pressure gauge. It has a diaphragm that prevents fuel from reaching the gauge (inside the driver's compartment). The driver's side of the isolator and the line to the gauge are filled with a fluid that transfers the pressure to the gauge. |
