Hydraulic lifters and closed cooled 1075’s?? >
Hydraulic lifters and closed cooled 1075?s??
Old 05-16-2019 | 11:26 AM
Default Hydraulic lifters and closed cooled 1075’s??
Couple questions regarding 1075’s....
Why don’t engine builders rebuild with hydraulic lifters, even if it means loosing a little HP but making it less maintenance intense. Also, why hasn’t anybody put closed cooling kits on the 1075’s with all of the salt corrosion issues on the heads??
I would think a closed cooled, hydraulic lifter 1075 would be a super nice engine.
302Sport is offline
Old 05-16-2019 | 11:58 AM
I thought I had read this has been addressed. I believe Eddie young puts hyd cams in them. Not sure about closed cooling
flat rate is offline
Old 05-16-2019 | 01:28 PM
So what makes for such a terrible maintenance/rebuild schedule on the 1075's, the solid lifters?
Marginmn is offline
Old 05-16-2019 | 02:30 PM
I'm interested in this answer. I expect the trouble areas to be valvesprings, rocker arms and lifters. I also expect they would not like adjusting lash. Let's see what people say...
NautiSouth is offline
Old 05-16-2019 | 04:11 PM
Teague Custom Marine uses hydraulic valve components in everything up to their 1200's. 1300hp and up is solid due to the fact hyd cant take the increased rpms.
bigfarmer is offline
Old 05-16-2019 | 04:21 PM
I would think the hydraulic lifters would cut down on the maintenance *(i.e. valve lash requirements and simple wear and tear) more than the rebuild schedule. I also agree with whomever said they wouldn't go bigger than a 700 v-8. Even with the power-outer that's a big number for a conventional gas burner IMHO. One can get A LOT more power from a v-8 but the more power the less reliability. To bad there's not an easy way to make the turbines more user friendly and usable. There is no other engine that makes that kind of power with so little maintenance. There's a reason they strap a couple of those to an aluminum tube, fill it with 300 people and launch to 30000 or more feet off the ground.
iamjoe is offline
Old 05-16-2019 | 08:45 PM
Hydraulic lifters have been done on 1075’s. New hydraulics can make very very close to the same amount of power as solid rollers. Johnson’s seem to be the way to go for HP marine and automotive applications.
apex svt is offline
Old 05-16-2019 | 09:19 PM
The 700SCI makes over 900hp with stage 4 upgrades. The 700 is basically a 525 with a blower, but pretty basic internals. I would think with all of the high dollar parts and quad rotor Whipple on the 1075, if you closed cooled it and put in a hydraulic lifter setup, it should be able to make 1000hp for a very very long time.
302Sport is offline
Old 05-16-2019 | 09:34 PM
we boat alot,I check the lash twice a season,takes a couple hours start to finish(both engines).when done right,,the tension for the supercharger belt will barely move when idling.1075's in a 46 outerlimit.
sutphen 30 is offline
Old 05-17-2019 | 10:02 AM
Bullhead's Avatar
http://www.pmefi.com/
Mark Boos....he is the guru for 1075's....super nice guy and is very free flowing with information
Bullhead is offline
