-   -   Getting some leaks (https://www.offshoreonly.com/forums/general-boating-discussion/360782-getting-some-leaks.html)
Prestigeworldwideee 05-22-2019 05:09 PM
Getting some leaks
I’m pretty sure that I’m getting leaks from my rub rail. I get water coming into the engine bay on identical sides at the joint in the hull and in my cuddy. I’ve decided against sealing the leaking spots in the engine bay, I think that’s the design to indicate bad rub rail seals? Is it? Should I pull the rub tail off and check under it? The rub rail needs to be re-caulked regardless so what’s the best method, slow steady hand and 3m marine silicone caulking?
tmmii 05-22-2019 07:30 PM
is rub rail underwater? If you want to seal it just remove rub rail at back of the boat and silicone the hull/deck joint.
how low slung is this cuddy?
Could be the hatch.
Prestigeworldwideee 05-22-2019 09:57 PM
Well, there is no hatch and the rub-rail visibility needs to be re-done. There’s sections actually missing caulking and I can see where in the cuddy it’s leaking along the rub-rail joint. The stern rub-rail is in the water when the boats not in motion. Is it fairly easy to remove from the back rub-rail to seal it? I’m just worried that I’ll seal the wrong spot, water will get trapped in the rub-rail, expand and ruin something during the winter....
phragle 05-22-2019 10:08 PM
looking at pics, it shouldnt be underwater..... And do not use 5200. I dont care what your mom's boyfriend's cousin's buddy tells you, do not use 5200. You want a sealant not an adhesive. you are not permanently attaching the rubrail and screws.
Griff 05-23-2019 12:50 AM
The proper way to do it is to remove the rubrail and then seal the joint between the hull and deck.
You can use 3M 5200 for that and it will strengthen the joint as well.
When you reinstall rubrail, put some silicone into the holes before you screw it back on. You should not need run a bead silicone on the actual rubrail.
Prestigeworldwideee 05-23-2019 05:50 PM
its submerged enough at times, especially when people are sitting on the back platforms, the water goes over the platform at that point.
speicher lane 05-23-2019 06:04 PM
Easiest confirmation is If you pop the engine hatch when you have everyone in the boat, you will probably see water coming in at the seams...3m Silicone will stay flexible and seal up the seam where the hull and deck meet and each screw should be pulled. Using 5200 will work but if you have to replace a section of the rub rail backing - you are in for a fight to get it off (5200 will hold trim tabs to a hull so it will definitely hold a rub rail).
Long story short, your in for a bit of a job but you have to seal the hull/deck (behind the rub rail) and each screw hole
phragle 05-23-2019 06:19 PM
If he uses 5200 to stick the rub rail on, and he or somebody else ever tries to take it off, they are liable to rip up the shoebox joint pretty bad..... 5200 on the hull to deck in the joint is good, but make sure its cured before installing the rub rail.
Prestigeworldwideee 05-23-2019 06:25 PM
I never intended to use 5200 to put the rub-rail on... anyways speicher lane -sounds about right to me. I don’t wanna seal the hull joints, I think I’ll run into problems later but pulling the rub-rail, sealing the screws and caulking the rail is what sounds like I’m gonna have to do. Thanks for the help, I originally was just gonna seal the rub-rail but I see how that could only solve half the problem. I’ll update this when all is done.
