GIL sbc exhaust?
Old 08-09-2019 | 08:09 PM
Originally Posted by northernoffshore
what out drive do you have??
Alpha 1... down the road I'd like to upgrade to a bravo 1.
DjMikeyC is offline
Old 05-13-2021 | 07:16 PM
Default do you no anyone that has sb gill exhaust thanks
cant find anything did you use the gill thanks tom
Tom Murphy is offline
Old 05-23-2021 | 12:31 PM
looking for gill small block manifolds .can anyone help
Old 05-23-2021 | 01:07 PM
SB
Use the Y with the 4 port tstat housing. Works great.
The newer 2 port can cause issues when the internal bypass corrodes more open or more closed because the Alpha pump doesn’t pump near the water volume as the Bravo. This is also why there is a special 2 port for the Alpha. It is cast with Name Alpha on top. Do not think of using the other one.
SB is offline
Old 05-24-2021 | 07:43 PM
Default smallblock gill
looking to by a set not having any luck
