Cig CC from Salt to Fresh at LOTO
Are there any long term updates on this process? I am currently going through the same thing with a much older boat that spent a longer time in salt water. While I feel it was well maintained, it definitely has an issue due to salt water. I added to another thread regarding Marine Machine steering and a replacement shaft for a cylinder so I won’t repeat that here. However, after reading about going from salt to fresh water the main thing I’m seeing is changing the anodes to magnesium from zinc or aluminum. Have you found any other obvious areas of concern that would keep the boat off the water? In other words, not cosmetic issues or minor things, but something similar to the steering. My boat is an inboard outboard so it probably has more items that have been exposed to salt. Thanks in advance for your help
