First Boat Opinions
Old 07-12-2019 | 09:07 AM
What is your annual boat ownership cost budget?
TexomaPowerboater is offline
Old 07-12-2019 | 09:14 AM
Ing's Avatar
Ing
Veteran: Marine Corp
Many good suggestions and I'll add Velocity and Checkmate. Keep it simple with stock power. Trim tabs and external steering would be a plus. Good luck.
Ing is offline
Old 07-12-2019 | 09:23 AM
Originally Posted by liberator221
we went with powerquest over baja because it has more cockpit room. more space between back seat and front seats. all in whats important to youl
The idea of more cockpit room sounds nice if I want a cuddy.
renegade800xp is offline
Old 07-12-2019 | 11:10 AM
Originally Posted by rak rua
First boat and you're still young so if you enjoy it, there'll be many more.....
If you buy a modified setup with big power and lots of work done, it's gonna cost you more on time and maintenance. That's the nature of the beast. All boats cost you money but the hotter ones cost you more. Twin engines are great but once again, more money on maintenance and a touch more on fuel. Don't get burnt buying too much boat first time round.
Buy a single engine, stock power (probably 496 or 496ho) with a good history that's been cared for. Survey hull, particularly for wet transom/stringers. I reckon Baja is hard to beat, straight bottom, easy to drive and pretty good room onboard. A great boat to start with, and they look nice too. Outlaw Vs Islander....... up to you, whichever you prefer layout wise.
My 2 cents worth, happy shopping,
RR
I would like to buy an unmodified and never really had my eye on anything modified as it just doesn't make sense right now.
A single is the only thing I need (the reason for staying under 26') and would prefer not to pay for maintenance and fuel for two engines and drives.
I was thinking an islander just because of the added room to bring friends, but prefer the looks of the outlaws.
Old 07-12-2019 | 11:22 AM
An open bow is going to give you more space and room for friends and coolers. You may want to look into a Cobalt open bow. They hold their value and are well built. Usually they came with the bigger motor as well. It may be a good way to get a boat that is into the 60mph range and not lose to much money if you decide you would prefer a cuddy and performance boat. Also with a being your first boat the open bow is easier to dock and grab lines with the open front.
DBleil89 is offline
Old 07-12-2019 | 11:31 AM
Originally Posted by JKetels
I live in North Liberty where you do and have a 288 Sunsation that will be up for sale soon. It will be a bit higher priced than your budget, but let me know if its something you would ever want to take a look at!
That is a good looking boat, might be interested in a year when I have more income to make it "seem reasonable".
Old 07-12-2019 | 11:43 AM
Originally Posted by jtbooten
I agree with the above comment about sticking with stock power. BUT with 2 496 boats I’ve been around, they had a lot of electronic issues and to diagnose, they needed a mercury scan tool that cost several hundred $. Graduated college in 2010 and bought MY first boat, a 21’ Baja Hammer. It was a good first boat but it’s not for big water IMO. Small fresh water lakes it’s perfect. Never boated on the river so I cannot comment there. Since then, I’ve had a 19’ jet boat, 27, 29, and now a 32 Fountain.
A 27’ Fountain may be a good fit for you. On an aluminum trailer, it might be within your trucks towing capacity. I believe the dry weight is 4700 lbs. I’m partial to Fountains but early to mid 90s and up, they all have hydraulic steering and K plans. Not a standard feature on a lot of Bajas. I like the 502 mag the best so far. They are fuel injected so they start a lot easier than carb motors. 27 with a 502 would probably hit high 60s mph. Have decent stock reliable power. If this is a hobby you feel you will continue, don’t start off too small, you will alway want to go bigger. After a couple years the 27 will feel small. There are a lot of other nice boats out there like Nordic, Checkmate, Sunsation, Formula, and etc. but I cannot comment on them.
I feel pretty confident in my mechanical skills with 8 years of experience working on snowmobiles. I have good relationship with people who had 496s in the past and know one of the guys who own Hawkeye now.
I would probably stay away from a hammer or a boat with a shallow deadrise because the Mississippi can get pretty rough on the weekends. A fountain 27 sounds pretty nice with trim tabs and hydraulic steering.
Old 07-12-2019 | 12:52 PM
Originally Posted by Sydwayz
What exactly is your tow vehicle? I think that may be your limiting factor. Remember, that Towing Capacity number is with NOTHING else in the vehicle, just the driver. Passengers, cargo, coolers, etc. etc. all subtract from your GCWR.
I had a 26' Sonic with a 500EFI on a cheap aluminum trailer for my first boat. It was 7280 lbs. total. My Tahoe was BARELY enough truck with a 7500 lbs. rating.
Good point thanks for pointing that out, got a 17' GMC Canyon crew cab short bed. Website says 6000lbs so I was off a bit, would probably check the owner's manual to be sure.
Old 07-12-2019 | 01:40 PM
Originally Posted by iaoutlaw
NL resident as well. JKetels sunny would be a great boat has a fresh 500EFI in it but like he said a little above your budget. I know of another guy in town that might be looking to move his 25OL 496 mag (not HO) in the near future.
Yes, but thinking more about it it may be out of the question to tow it with my current truck.
I will have to keep my eye out for it, thanks.
Old 07-12-2019 | 01:44 PM
Great question I am not quite sure, will have to look more into my spread sheet to find some numbers and do some calculations.
