-   -   Injector cleaners as maintance service? (https://www.offshoreonly.com/forums/general-boating-discussion/362202-injector-cleaners-maintance-service.html)
Raceme9s 08-13-2019 01:37 PM
Originally Posted by BUP (Post 4701822)
Thanks guys and DD for good words for what I do daily. - yes you are more than welcome to send any fuel related items to whomever. On my end I prob spend way too much with each set of injectors but I am one of those who measures 11 times and cuts once. My goal ALWAYS is to have the spec flow volume rates within those rated numbers and as close to possible perfectly balance in flow volumes across the board. I always try to be at 3 percent and under for that balance.
Many oems say 7 percent is good but again I really strive for 3 percent and under for flow balance. Most people fudge these numbers and WRITE down that all injectors flow the same number across the board . That is a BS report - IMPOSSIBLE to have all 8 injectors or 6 injectors or 4 injectors to FLOW the EXACT SAME PERFECT flow volume numbers for many of the test procedures.
Like I said I try and perform many cleanings & tests to get all the injectors as close to perfect as possible. That is not easy to do with marine fuel injectors but I spend the time and money to make that happen for all sets of fuel injectors as best I can. .
Sorry about the PM box being full I ll have to read a few and delete some. THANKS
send me your contact info so I can send them to you
