Can't shift into reverse
Was boating over the weekend and had one of my motors stall out while I was in reverse. Was able to shift into neutral and start motor. Now shifter will go into forward and back to neutral without problem but won't shift into reverse. Checked the shift cable back to engine and it is working fine. It appears the shift cable going into the drive is the problem. 525 motors with XR drives. Any idea on a fix?
Bravo's don't like to be shifted without the motor running. My guess is its either the lower shift cable or drive shift fork,
Originally Posted by AllDodge
(Post 4702760)
Originally Posted by sheperd
(Post 4702817)
That's my guess too. Any idea how to fix it?
Originally Posted by tmmii
(Post 4702834)
mercury has a little plastic deal that you can pull the shift cable from the linkage in the boat and use it to adjust. Sorry I don’t know the part number but may find something on google searching bravo shift adjustment tool or something to that effect. https://cimg0.ibsrv.net/gimg/www.off...cf773b6806.jpg Install as shown https://cimg2.ibsrv.net/gimg/www.off...ad5a9e67a9.jpg I would see if there is still 3 inch spacing on shift cable, and if its there, then pull the drive and check if cable is still in position. If everything checks out, remove the rear cover from the upper and check out upper shift fork. If it ever happens again and does not move easy into neutral, keep a little pressure on shifter while someone else jumps across the slave relay to bump the starter |
(Post 4702867)
I think your talking about 91-17262 which is used to set the lower shift cable position
Disconnect upper shift cable from assembly and then move the shifter and see if it moves freely.
If it does, then its most likely the lower cable, shift linkage assembly and detent ball or the shift fork. |
(Post 4703021)
Thanks for the input but I don't think a shift adjustment tool will help me. The cable will shift into forward but is completely seized when trying to put in reverse. How do you jump across the slave relay to bump the starter?
https://cimg1.ibsrv.net/gimg/www.off...43f274fb10.jpg |
Thanks. I'll give it a try. |
| All times are GMT -5. The time now is 09:45 PM. |
