Closed Cooling Help/Advice >
Old 10-04-2019 | 10:02 AM
I have a few ideas as I have had issues with mine over the years:
1) did you "burp it" air can cause issues in the closed cooling.
2) related to above drill small holes in edge of thermos - lets air bleed out
3) triple check raw water flow ... thruhull, valve, impeller, oil coolers (if old check not clogged), and make sure all clamps are tight. I had a busted clamp - let in air - caused heating issues.
Good luck Bro
Swamplizard is offline
Old 10-04-2019 | 10:14 AM
SB
Too bad it's fuel injected.
Raising the timing at idle can significantly reduce exhaust temps unless it's already somewhere say between 16-20.
SB is offline
Old 10-04-2019 | 03:03 PM
An important piece of missing information is that he isn’t using oil coolers of any kind. His issue is overheating after a hard wide open run when the oil temps would naturally be sky high without coolers. The temps don’t rise until returning to idle speed if I have his description right.
ph1971 is offline
