BlackHawk Drive question...
Just a general question... How much will a Blackhawk drive raise the prop from a standard length Bravo drive?
I was able to find the below post on a search. Can anyone verify that it is accurate? My Bravo drive now is deep. 8" below the keel. I don't think that adding a -1, -2 or-3" shortie will do too much. I am not considering in any way messing with the transom because it was just replaced recently. But...… it looks to me (if a Blackhawk raises it 8-10") that that could be a fun thing to do.
The post that I found: 06-01-2006, 10:02 PM #24 MOP Registered Join Date: Nov 2003 Location: Jamesport, New York Posts: 368 Default Re: blackhawk driveMORE! It is a direct bolt up to your Bravo shield and does the same thing as raising the X, my BravoX prop shaft is roughly 8"'s below the keel the Blackhawk mounted on the very same shield put the prop shaft about 2" above the keel. When running the only thing in the water is the skeg and the bottom of the props, and by the way the "Rooster Tail" was super! If you know where to look there are more around then the Skeptics think, setup right it will "Lay Waste" to a shortie which still has a fair amount of drag by comparison! Phil |
PM i2zh2o, or i2zh20 here or PM me and I will give you his number. He las lots of Blackhawk experience.
Blackhawk
The blackhawk is really that short I had one one my 21 ft v hull whit stock bravo it was 6 below and whit the Blackhawk it was 2 above
keep in mind your boat have to have natural bow lift (rocker ) In the bottom because the drive is a full surface drive and dont provide bow lift . Parts are all Bravo one in upper and bravo 3 on lower except the vertical shaft but max machine worx can supply them and even convert to xr internals I ended up whit a imco -3 that had same performance and handling but provided more bow lift that my hull needed hope this helps bor https://cimg4.ibsrv.net/gimg/www.off...428f58865.jpeg |
That would be so cool on the 20. DO IT!!
If you can find one, Blackhawks are like buying gold.... you'll never lose your investment. FYI... I still have that -2 shorty if you're interested. From talking with Lip-Ship years ago, the -2 will free up the hull quite a bit. |
Just putting it out there - I have 8 brand new housings and the parts to build 4 complete units with ratio of your choice :)
Originally Posted by Mbam
(Post 4719546)
It's a little fuzzy... :D:ernaehrung004::drink: but we spoke about that in Key West. I'll give you a call after the Holidays and we'll talk. I'll be bringing the boat over to Mike at FineLine sometime in the near future. Craig |
Originally Posted by OldSchool
(Post 4719593)
Hey Marc,
(Post 4719346)
l A couple things to consider, first is Blackhawks need EFI I had carbs and had to turn the idle way up to be able to put the Blackhawks in gear without the motors dying My boat ran 82 mph with bravos, ran 85 with Blackhawks but bow steered really bad, Blackhawks gave zero bow lift I believe the props are hard to come by so probing it may be an issue Because the idle was turned up and the drives grab so much water the boat idled at like 10 mph |
| All times are GMT -5. The time now is 03:43 PM. |
