Single lever throttle?
Old 01-28-2020 | 06:08 PM
OldSchool's Avatar
Default Single lever throttle?
I can't seem to find one online.....but I have not called any of the manufacturers yet. Does anyone know if any of the Companies (Gaffrig, Livorsi, etc) will make one? To clear up any confusion, see the picture. I want a setup like that and it will be mounted in a console between the seats, but without the shifter... Just the throttle for an upcoming project..
OldSchool is offline
Old 01-28-2020 | 06:28 PM
I don’t know this person or have any affiliation with the seller. But looks like livorsi makes them. Here’s one I found.
https://rover.ebay.com/rover/0/0/0?m...2F322223386722
Smoke eater is offline
Old 01-28-2020 | 06:30 PM
Here’s one brand new from them. Idk if this will work for your application but I think this is what you are referring too.
https://rover.ebay.com/rover/0/0/0?m...2F401629783804
Old 01-28-2020 | 07:08 PM
OldSchool's Avatar
That's exactly what I'm looking for. Thanks!! I'm not much on buying stuff from Ebay, will order a new one...
Old 01-28-2020 | 07:29 PM
Awesome. Glad I could help out!!
Old 01-29-2020 | 12:42 AM
All of the brands can be made as a single lever. Each section is its own lever and they bolt together.
Latham ones are not nearly as deep if that may be an issue with your console. Also the nicest IMO and probably the most $$.
Latham Marine
Also there are some older sets in the swap shop that could be made into a single lever
Griff is offline
Old 01-29-2020 | 08:33 AM
offshoredrillin's Avatar
i had one but sold it.. check w bbystwy on here to see if he used it. it has shifter as well... i put the hardin marine one in my 20.. they have all the options..
https://www.hardin-marine.com/p-1377...ustomizer.aspx
offshoredrillin is offline
Old 01-29-2020 | 09:00 AM
If any one is still looking I have a single throttle and shifter exactly like the one in the pic but a different trim sw and black and I have a single gaffrig throttle only I went with a different set up for next year.
Bobbyyeah93 is offline
Old 01-29-2020 | 11:30 AM
TYPHOON's Avatar
Latham Marine
I have the Latham single in my race boats. Depending on how hard you run your boat I have seen the Livorsi style bend.
TYPHOON is offline
Old 08-21-2020 | 06:16 PM
OldSchool's Avatar
OK, I'm looking for a throttle like this one. I thought is was from Hardin, but that doesn't seem to be the case. Anyone know who makes this?
