-   -   Mercruiser 525SC Heat exchanger? (https://www.offshoreonly.com/forums/general-boating-discussion/365400-mercruiser-525sc-heat-exchanger.html)
BUP 03-18-2020 06:16 PM
there is some cheap coolers and exchangers out there. Thin areas and very poor brazing and even smashed tubes, I have seen on brand new units. examine what you buy inside and out.
BUP 03-18-2020 06:21 PM
Originally Posted by park35 (Post 4729712)
What is the size of your unit and diameter and how many tubes are inside and how many passes does the flow make ?
Also did you mount a remote reservoir in conjunction with the heat exchanger - mounted at a high point ?
park35 03-19-2020 10:16 AM
38in long by 5" dia...3 pass..3 stag raw water pump...water pressure at wide open...50lbs
park35 03-19-2020 10:17 AM
Sorry yes remote..tank up high
ph1971 03-19-2020 02:07 PM
I have the heat exchanger that came on a merc. 454 HO. It’s on a 625hp 540 now and I’m running a 140* thermostat. I boat in very warm water and my temps never exceed 150* at 30 psi at 5400 rpm. I don’t know how that translates to your 525 sci but for $200 you might give one a shot.
sailtexas186548 03-19-2020 07:48 PM
Anyone run the 5” merc exchanger with manifolds likes gils included (full system)?
