Gear oil OEM vs non OEM
Old 04-23-2020 | 02:27 PM
I like the Amsoil Marine gear lube. No, it doesn't work well with a worn out cone clutch, but works great with good parts. It also claims to not lose any lubricating properties with up to 10% water intrusion.
snapmorgan is offline
Old 04-23-2020 | 03:07 PM
Originally Posted by Ryan00TJ
I've switched from Merc HP to Merc Racing 90w and buy it 5gal pail for $276. Works out to $13.80 per qt. It does not leave sludge in the drive reservoir and does not need topped off like the Merc HP needed.
I've ran Mobil 1 Synthetic 75w90 before in a drive that had leaking seals. When the oil in resevoir bottle changed color, drive was torn down to repair and clean. Lower gear faces were allready pitted and needed replaced. Merc oil is labeled as being able to run with water intrusion to a degree.
That's a good point. I've only ran Mercury Racing 90W and had a leaking o-ring in the drive, at a poker run. Afterwards we tore down and with a menial amount of water going thru the gearcase, no wear/damage/anything. I guess I'll be sticking with that for now.
frickstyle is offline
Old 04-23-2020 | 08:03 PM
when konrad was developing there performance drive they needed a good gear lube and obviously werent going to buy merc stuff. They found royal purple to be the lube there testing liked and it mixed well with merc lube incase a customer needed lube and couldnt find royal purple. i was always going to try it but being lazy i have always just bought merc lube
flat rate is offline
