Battery 5/16 stud/post size be a restriction on amp/current? >
Old 04-20-2020 | 09:45 PM
Strip Poker 388's Avatar
Rob
Question Battery 5/16 stud/post size be a restriction on amp/current?
Im upgrading the Stereo in the Hustler, adding more amps etc. I got to thinking battery post size being a restriction. Like the small 5/16 stud on the Optima blue top or 6mm on the XS power, does it restrict current/amps?
Why do you run a 1/0 or larger wire when your restricted to the 5/16 stud? How much can flow thru a 5/16 stud thru a ring terminal to what ever wire size?
Also thinking on larger ah batts, Ive been running 2 of the optima Blue group 34m that has 55ah, If I went to 2 group 31m that has 75ah. is that a big difference in run time on the Stereo?
Thanks for any help
Rob
Strip Poker 388 is offline
Old 04-20-2020 | 09:46 PM
The stud should come out of a lead lug, so you have plenty of contact area for the cable end
sailtexas186548 is offline
