Extension boxes on stepped hulls >
Old 05-25-2020 | 04:39 PM
Default Extension boxes on stepped hulls
Whats your thought's on Extension box"s on stepped hull's? Have a 30' Eliminator eagle and looking to try and stabilize above 88mph. hard to keep up on the pad,walks really bad.just changed from 280 to 380 tabs but haven't tryed it yet. was thinking box's my help keep the drives tucked in. Thanks!
mod58 is offline
Old 05-25-2020 | 07:51 PM
Too Stroked's Avatar
Are you sure you don't have a prop problem? Too much stern lift will do some weird things and props are much cheaper to change.
Too Stroked is offline
Old 05-25-2020 | 08:13 PM
Thats a good point,The boat wasn't that bad 2 seasons ago and last season I added 175hp and thats when it got outta hand.I am turning it around 5800+ now verses 5200 with stock 32 bravos.
mod58 is offline
Old 05-25-2020 | 08:36 PM
TomFTM's Avatar
Try changing the prop rotation . Also a lot cheaper than putting boxes on .
TomFTM is offline
Old 05-25-2020 | 10:08 PM
tryed turnning them in,it was worse.
mod58 is offline
Old 05-26-2020 | 07:07 AM
2jz
Try a pair of bravo xs or cut diffuser ring aka barrel on stock propellers. It wouldn't lift the stern as much.
if spinning in problem got worse your getting too much stern lift tabs ain't going to fix that.
2jz is offline
Old 05-26-2020 | 02:44 PM
I know tabs are not the cure but they can't hurt.
mod58 is offline
Old 05-26-2020 | 02:50 PM
F-2 Speedy's Avatar
pretty good deal on a complete kit for twins on FB, 12 inch neutral boxes
F-2 Speedy is offline
Old 05-26-2020 | 05:28 PM
B38
Surface drives would solve all your problems.
B38 is offline
Old 05-26-2020 | 07:24 PM
F-2 speedy,Yeah trying to find out
cap size on shafts.
mod58 is offline
