Can GPS be fooled?
More positive rake helps bow lift. Not sure if cup will have anything to do with it. Generally, the bigger the blades, the more bow lift. Once in a while, Ill run into some of the old ss michigan wheels they used on the old scarab 3's and they have serious bow lift.
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
My Merc mechanic has a prop that he referred to as a "raker" that I was going to try. He said they were used a lot on outboards, and I think the diameter had been cut down some. Doubt if I can spin it; I think he said it has a 24" pitch - too much for my mill with 1.36 gears.
Anyone have a set of 1.5's for sale?
As long as you have three birds locked in it will be accurate. The problem is mainly with the max speed, which is accurate but it may not be in the direction you think. If your GPS says 80, then my friend you are doing 80.
Hmmmmm..
My understanding of how a GPS works in that it locks on a location at set intervals (once a second for arguments sake). The mathmatical calculation of the disctance between the captured locations and elapsed time is how fast your going (MPH).
Because of this current in a river will effect your speed. If your going with the current your traveling at your boat speed+the speed of the current resulting in a higher total speed. The reverse would aply if going against the current.
I also thought you needed a minimum of three satalites to get a position. My Garmin GPSIII+ usualy hits 5 or more. If you were to lose contact and only have two satilites to track from I dont think the unit would have enough data to calculate.
I have seem these units give highly suspect reading (Max Speed).
The error being at 100mph+ I dont believe that its being effected by the boat being towed
Yeah, if it came back with a reading of 125 MPH, I would know something was up! Since it was only about 6 MPH over the speeds that I had seen before, I thought there could be some possibility that it was legit.
I suppose the current could have had some effect. Water was up, and current was pretty swift. But I would also expect the 25+ MPH headwind to offset that some, too.
