Sportmaster Lower Removal
Old 07-22-2020 | 10:56 AM
Default Sportmaster Lower Removal
I have to remove my Sportmaster lower from a Bravo XR upper to have the skeg repaired. Two questions: How many bolts hold the lower to the upper, and can I remove the lower while the upper is still attached to the boat? Appreciate the guidance!
fasterfastech is offline
Old 07-22-2020 | 11:13 AM
TYPHOON's Avatar
Drain oil then remove 6- 5/8 nuts. Its a fairly basic job. Don't drop the unit after you take off the last not.
TYPHOON is offline
Old 07-22-2020 | 12:03 PM
There’s 6 5/8 nuts, and no zinc plate on a sportmaster.
Unlimited jd is offline
Old 07-22-2020 | 01:43 PM
I found four of the six 5/8 bolts are the remaining two near the front of the unit facing upward? Thanks, Auto machinic....lol
Old 07-22-2020 | 02:03 PM
yes
McKay is offline
Old 07-27-2020 | 01:59 PM
Thank you- the good advice helped.
Old 07-27-2020 | 02:03 PM
yes, 2 are pointed up, towards the front. A little hard to see if the drive is installed and trim rams are in the way
Old 07-27-2020 | 02:43 PM
I found by lifting the drive up the trim rams move out off the way enough to access these upward facing bolts.
Did have another Question about the sleeve that couples the two shafts together, can this be installed in any direction?
Old 07-27-2020 | 03:10 PM
For a bravo, Xr, sportmaster or imco sc yes coupler can go either way.
Old 07-27-2020 | 04:04 PM
Thank you!
