-   -   Mercury NXT shift linkage (https://www.offshoreonly.com/forums/general-boating-discussion/369127-mercury-nxt-shift-linkage.html)
f242 10-28-2020 01:55 AM
Hi!
I'm repowering with a NXT-drive and transmission... I can't seem to find any clues or hints on how the shift linkage (at the transmission) is connected leaving me to improvise and probaly fabricate a solution (if no other solution is found).
Do anyone with NXT-transmission have the time to take a quick photo of the linkage (the linkage that connects directly to the transmission, not the shift plate (if installed))
I find one bolt on the flywheel housing that seems to be in line with the shift mechanism but it would be really helpful if I can have a look at a real installation to determine if thats the way to go or if I should come up with som fabricated fixture to fit and mount with some of the other bolts...
Thanks in advance!
Kelly O 10-28-2020 06:33 AM
https://cimg1.ibsrv.net/gimg/www.off...c64792468.jpeg
The cable end (red) is fixed to a stud mounted onto the flywheel housing.
The cable holder (black) is bolted snug- so it can pivot- to the shift linkage.
Very simple setup.
f242 10-28-2020 06:46 AM
Ahhh, EXACTLY what I was asking for, a big thank you. I was on the right trackthen, the bolt on the flywheel housing is in fact used.... but mounted "in reverse" from what I thought... the end of the wire is not attached to the shift lever but on the housing. This would create "a lot" of movement of the wire? A lot compared to fixed wire shell and moving cable end... Anyhow... its easy to reverse the direction of the wire in my installation if wanted...
Again THANK YOU very much.
