Hull/Hot tub cleaner
I know you said it was hot tub cleaner. But this isint it as well is it?
https://www.imagesupplyinc.com/catal...wl-Cleaner-Qt/
maybe post a pic or the mfg on the bottles you still have left. Might be helpful for all. Because I could use a new hood cleaner as well. Don’t mind buying a case if it actually works
Here's what I got from the member on here. I've used it on painted stripes on the Fountain I had and on the gel of my current boat without any noticeable concerns. It is more a gel than a liquid and easy to apply. I use a square terrycloth floor mop.
They do not have a distributor you can buy from and the only way to buy it is if you have a business and order it by the case which is what someone did on Offshore quite a while back.
I was just going to have a friend that has a business check on the cost of a case if I remember it wasn't cheap my hull is black gelcoat and it never sits in the water but the previous owner must have let it in the water at one time as underneath the chaps on the outboard is some stains I wanted to get off before putting everything back together.
They make so many different things they lady I spoke to didn't care what business just a "business" and buy it by the case. She didn't even want to talk about cost unless I was business ordering.
Curious us what does it do so well? Might want a couple bottles for myself haha.
