Twin PS pump Manifold, installation issues! >
Old 01-11-2021 | 02:37 PM
Perfect, thanks!
Fasterboatman is offline
Old 01-11-2021 | 02:38 PM
Thanks!!!!
Old 01-11-2021 | 04:45 PM
Originally Posted by green lightning
I think once you put the tank on all your pump leaks will go away
I think too I need to block off the return line into the pumps and use these caps plumbed to the tank. Here is the tank and the caps:
Tank
https://www.hardin-marine.com/vsearc...hTerm=137-9050
Caps
https://www.hardin-marine.com/p-14617-billet-aluminum-power-steering-reservoir-dump-cap.aspx
That is what Hardin suggests anyway. But many thanks for everyone's help!
Maybe I can take her for a spin this weekend......
-j
Old 01-11-2021 | 06:16 PM
scippy's Avatar
Curious, for your hydraulic steering, is it only one power steering pump needed?....I have twin 572 cu in. & only one is mounted to one engine with an overflow / fill container next to it.
scippy is offline
Old 01-11-2021 | 06:33 PM
You only need one for the system to work but if the engine with the power steering fails it is tough to steer
green lightning is offline
Old 01-11-2021 | 06:50 PM
Rookie's Avatar
Derbery, that rings a bell........
I think he left the gate unlocked...
Rookie is offline
Old 01-12-2021 | 08:49 AM
Or left the key under the welcome mat.....
Old 01-19-2021 | 09:29 AM
The new tank and plumbing was a bear to get done, and finding a spot for the tank was a lot of fun, but it seems that all was as advertised! Worked like a charm! I can run just one engine, and no issues with oil pushing out into the bilge.
Thanks to all here for you advice and help.
Now to continue to DE-Leon-ize the rest of the rigging.
-j
Old 01-25-2021 | 02:28 PM
Well it works just fine no leaks, but now the steering is rather "jerky". The tank seems to have a bit of foam. I have double checked all of the connections, and all seems fine. Had a someone else check the routing and all seems correct. I spun the wheel about 15 times each way, but the symptoms remain. I will keep all posted, but hopefully, it is either just air in the system, or maybe some water got in. I going to flush the fluid, and replace this weekend unless someone has a better idea.
Thanks again to all!
