Dry exhaust question
My exhaust was dry to the very tip. I installed these last summer and it made a huge difference!
https://www.hardin-marine.com/p-1262...-mufflers.aspx
I'm sorry to add a possible stupid question here. Some of the above replies say the tail pipes are dry until the very end. How is that possible? isn't it wet until the very end, than exiting the water overboard at a different location away from the tail pipes?
I think the CMI website has some good explanations on it.....
you simply inject water into the exhaust it the very end, I have stainless marine. I cut the risers before the water enters the exhaust the exhaust stream and extended the inner and outer tubes then welded the part that injects the water at the end. That took care of reversion issues.
I don't mean to change the direction of this thread.....I don't know! seafordguy is exactly what I was saying. Unless I'm crazy the water never enters the exhaust. It's on the outside of the exhaust for cooling and inside the double wall. The possible reversion issue comes, I believe, at an idle. The water is exiting the double wall portion of the tail pipe and is being sucked back into the exhaust pipe portion and sadly back into the engine/cylinder. By closing off the double wall and welding a bung to have the water exit separately away from the exhaust it does not get sucked back in. Unfortunately since all these pos headers end up leaking somewhere you still hurt your engine. But, that is an all together different subject
I run dry to the very tip than out.
The difference over traditional wet is its at the very end and has to come way back to do any damage.
For most that is enough, BTW my chitty e-top headers did finally start leaking,,,,,,, 21 years after new.
Half of that in salt water.
