-   -   vessel view on Garmin and Raymarine! (https://www.offshoreonly.com/forums/general-boating-discussion/371269-vessel-view-garmin-raymarine.html)
30outlaw 04-20-2021 12:57 PM
https://www.mercurymarine.com/en/us/...ine-displays-/
This is great news to be able to get away from Simrad displays!
poulsen11@yahoo. 04-20-2021 02:24 PM
wondering if they will update firmware on older garmin units so they will have the same capability
SabrToothSqrl 04-20-2021 05:57 PM
If they did that, you wouldn't buy a new one ;)
30outlaw 04-22-2021 07:40 PM
depends on "older" i would say at least need n2k.
Dave M 04-23-2021 12:12 PM
What is the difference between this and the NMEA 2K gateway? That's what I am using now along with smartcraft gauges.
30outlaw 04-23-2021 01:11 PM
well disclaimer I am not an expert nor associated with anybody just my personal projects and research....
the gateway took smartcraft data and put it onto a n2k network so any mfd could have engine data using that mfd's generic gauge interface. biggest downfall here is you get generic faults if any at all
the vessel view link was for mercury/simrad/Lowrance/bg mfd's ONLY and gave you the actual mercury vessel view gauge interface and the big advantage here is faults, vessel view interface will give you the fault description (ex. engine misfire cyl 8)
the new connect appears to be like the vessel view link just for Garmin and raymarine mfd's
I did a pretty extensive upgrade from gauges to all mfd's on a boat recently and went with simrad for the very reason to get the oem mercury interface/vessel view software. had this been available I for sure would have went a different route with the displays! I don't think simrad displays are bad nor am I not happy with them, there are just better displays out there.
poulsen11@yahoo. 04-24-2021 09:41 AM
thank you for giving real life knowledge. Should have done my own research. Thought this was a software upgrade, but turns out it is a hardware upgrade. Of course in true to form fashion nowhere can you get pricing info nor can you purchase without a dealer.
30outlaw 04-24-2021 10:12 AM
it was announced just a few days ago, give it a little bit... Given the fact that it does about the same thing as what the vessel view links, I would have to assume on the hardware side it’s going to be in at $1500 ballpark
Holy Smokes 04-26-2021 02:59 PM
So, I'm currently installing a Garmin 9" MFD and intrigued by the SmartCraft Connect. Did a little digging and came up with this:
Product data sheet:
https://samerwebapp01apncus01.azuree...730_scc_ss.pdf
Manual:
https://samerwebapp01apncus01.azuree...way_manual.pdf
Checking local dealer to get a cost and availability.
30outlaw 04-27-2021 07:26 AM
1 Attachment(s)
Product data sheet:
Manual:
Attachment 577050
they are available and in stock and right on par with the vessel view link $1199 retail when I called my local dealer.
