Ssm iii
Hello, looking for advice as to the torque specs for the plug-in bearing support aluminum housing bolts.
Also the gasket material that I should use. Mine is leaking, tried to redo with Permatex RTV but still leaks oil.
I will check the casting to see if it is warped.
