Winch Strap.
What does everyone recommend for a winch strap. Mine is all sun faded and looks as if it is deteriorating. Not a big boat, 29 Velocity with a single but prefer a little overkill. There used to be someone one on OSO that would make them but I couldn't locate him.
Thanks,
Padraig
Thanks,
Padraig
On the boats I've had, it's pretty much been just the standard 2" wide X 20', 5,000 pound strength strap. Dual-drive on the winch is preferable but not required. I believe you can get a variety of gear reduction ratios to make it as easy as possible to winch up.
Baja 252 Islander
Baja 252 Islander
I used to make them but don’t anymore. Looks like Amazon has several to choose from and some made in the USA. Most have a 10,000 breaking strength which is stronger than your winch.
Most local “rigging” shops can make you a winch strap also if you’re not an Amazon fan.
I ordered my winch strap from the the below place. I got a 10K winch strap, 2" X 20' from them and they will make them in a variety of colors for you. It's model 1807. Custom length to your needs.
https://customtiedowns.com/product2....list=1&store=1
https://customtiedowns.com/tie-downs...-winch-straps/
this who i went with as well, i got 4 inch. the Tiger is about 12k with fuel, i cant find any 3 inch for transom though...
I use Rodsaver 10k rated with loop and hook. They're typically around $25.
