Help, any Ideas?
Old 08-03-2021 | 10:58 AM
Nice thing abt having 2 engs is you can swap stuff around to troubleshoot. I would start with ign components; coil, dist, external spark boxes if applicable.
Make sure spark plugs and gaps are the same between engs. 0.035" would be a good place to start.
zz28zz is offline
Old 08-03-2021 | 01:26 PM
Originally Posted by Wally
Another avenue to look at is the props....i had one prop from a set that were supposed to be 23p each......problem was that one prop had blades closer to 24.5P and it was loading the motor down too. They must have been worked at some point but you couldn't tell just by looking at them
This
Swap props from side to side and run it( your shifters will be backwards)
and see what it does
JaayTeee is offline
