Lake Cumberland questions
Old 08-25-2021 | 01:39 PM
Originally Posted by H20 Toie
Hi Brad we are running a Cigarette 42x, ok Harmon creek is a must see
H2O,
Unless you're actually running in the PokerRun, Harmon is where it's at. Since the administrators did away with the "flight" format, and the boats can run wherever whenever, there's really no place on the lake to sit and watch them run. When we put in at Conley, we make the run to State Dock to check out the hardware, then head to Harmon to check out the software. We always end up spending the rest of our day there, other than maybe heading to Wolf Creek Marina for dinner. You can raft off or idle the circuit or a little of both. It's always a good time.
Thanks. Brad.
Model Machine and Precision LLC
(937)545-8991
Brad Christy is offline
Old 08-25-2021 | 01:54 PM
H20 Toie's Avatar
Think I got it worked out. yes I'm in the poker run and have a slip at state dock
Thanks for everyones help
H20 Toie is offline
Old 08-25-2021 | 02:09 PM
H2O,
We'll get to watch you as you swing though Burnside for your card, then. As you're pulling away, look up and to the right a bit. Well be on the deck, out on the point between the North Fork and the Main Lake, directly above the old railroad tunnel. Give us a honk.
Thanks. Brad.
(937)545-8991
