Engine guru question!
Old 08-30-2021 | 08:43 PM
Good call to drain and check the oil for debris.
Pickup tube come off?
Debris in pickup
Bearings
Thicker oil may help with pressure, but it's just masking a problem if oil pressure used to be 30 higher.
Curious to hear what the oil and filter look like.
540Fever is offline
Old 08-30-2021 | 10:59 PM
Had this happen to me after a rebuild, had the motor apart multiple times, then found the oil lines were reversed to oil cooler, would show at high rpm and cook the oil, pressure was no existent when I got that hot. Worth a shot to look at, also on boat like that, I would figure there are oil temp gauges, if there are you temp readings should be off motor to motor or at least pre/post rebuild if the lines are wrong.
shadowvette33 is offline
Old 08-31-2021 | 06:17 AM
jeff32's Avatar
Originally Posted by bobkatz
what viscosity oil?
20-50
jeff32 is offline
