Amsoil VS Walmart Mobil One >
Old 04-27-2022 | 09:38 PM
Originally Posted by HOSSMAN
I've always like Valvoline VR1 20/50 because of the added Zinc content but I'm not a scientist or expert on the fundamentals of molecules in oil and how much none of that makes a difference with how often we all change the oil in our boats. Sometimes it comes down to availability and what you can always rely on being able to get. Being in the automotive industry everything is getting harder to get (oils, filters etc.) so always buy extra!
Both VR1 and Mobil1 15w-50 have the same zinc level at 1300ppm. Lower viscisity Mobil1 oils have 800-900ppm.
Griff is offline
Old 04-27-2022 | 10:52 PM
SB
Quite close.
vr1 has 1400 zinc 1300 phosphorous
https://sharena21.springcm.com/Publi...0-ac162d889bd3
mobil 1 15w-50 1300 zinc 1200 phosphorous
http://www.billswebspace.com/mobil_1_product_guide.pdf
SB is online now
Old 04-28-2022 | 06:24 AM
mobil twin v oil.
sutphen 30 is offline
Old 04-28-2022 | 06:55 AM
SB
Originally Posted by sutphen 30
mobil twin v oil.
:thumbs
1700 zinc 1600 phosporous
SB is online now
Old 04-28-2022 | 08:33 AM
The only caveat to the second viscosity number is that it`s measured at 100*C (212*) .
For example a 15-50 weight oil has 50W oil viscosity at 212* , my engines run oil temp at 170-180* at cruise so Am I never seeing 50w , is it somewhere between 15-50? That`s above my paygrade..
A straight weight oil is not going to have that problem.
ICDEDPPL is offline
Old 04-28-2022 | 08:36 AM
Yay! An oil thread!
thirdchildhood is offline
Old 04-28-2022 | 09:01 AM
SB
Originally Posted by thirdchildhood
Yay! An oil thread!
Snowed here last night, so here I am
SB is online now
Old 04-28-2022 | 09:36 AM
Good info here from K1.
My STOCK 496HO main bearing clearance were .002" 1thru4. .0025" #5. Typical tight GM production line specs. Hence why Merc 40w is recommended spec.
main bearings after 600ish hours on $12 15w40.
Ryan00TJ is offline
