Ecm programming
Old 05-21-2022 | 08:57 AM
Default Ecm programming
Any recommendations to send it to 5.7 mercruiser BIII
Bt Doctur is offline
Old 05-21-2022 | 02:03 PM
Why have it re programmed??
Griff is offline
Old 05-21-2022 | 10:32 PM
motor cutting off at idle, will run at anything above 2K but quits at idle. I suspect its not programmed for the 5.7merc
Old 05-21-2022 | 11:03 PM
That sounds a lot more like an IAC issue
Have you scanned it for codes??
Griff is offline
Old 05-22-2022 | 03:34 PM
agreed.
id scan it first unless you knowingly replaced the ECM and are now having problems…
1MOSES1 is offline
