Rinsing the engine
Old 05-26-2022 | 07:12 AM
Default Rinsing the engine
Hi, I have just purchased a Chris Craft 245 Limited with a 2012 Mercury 525 engine. It is always used in salt water. I was wondering if it would be a good idea to wash rinse the engine bay with a handheld pump to wash off any salt residue which might start building up from the humid air. Then spray it with a corrosion inhibitor.
I used to do this every time I was out with my jetski and after 6 years the engine looked like new. No signs of corrosion at all and never had any issues with belts slipping or splitting due to the corrosion inhibitor.
Any thoughts on this please?
Ku310R is offline
Old 05-26-2022 | 07:38 AM
Wally's Avatar
Were doomed!
Its not a problem to do that. I used to spray down the engine on my old scarab after we came back from FL and sprayed it down with T-9 boeshield.
I used a product called Salt-away...
Just don't soak the alternator...indirect splashing is ok......obviously cover the spark arrestor so nothing gets down into the engine...and either cover the distributor with a plastic bag or try and stay away from it as much as possible with the spray. And depending on what you have for valve cover plugs you can either tape them over to keep water out or just steer clear of them. Start the engine afterwards on the hose and let it warm up (or in a fresh water lake) ....then when its cooled a bit spray it down.
-Wally
Wally is offline
Old 05-26-2022 | 07:39 AM
I've not really seen any build up on an inboard boat engine. I run in salt water and have had several boats, and the engine bay is (of a well working boat) usually spotless. a PWC engine is much closer to the water line with a much higher chance of water getting into the engine area.
I think you'd just be more likely to cause issues with rinsing a boat engine. I don't know the temps where you are, but usually when you winterize a boat, you can spray down corrosion inhibitor 1x a year.
SabrToothSqrl is offline
Old 05-26-2022 | 07:50 AM
Veteran: Army
Depending on the size and location of engine room vents, it's possible to get some salt spray where you'd rather it wasn't. After a few uses you will see the whitish buildup and then those are the areas to rinse or wipe down after a run. Unless you have a raw water leak you shouldn't have to aggressively wash away salt after every use.
All of the stock Merc wiring connections have a degree of water resistance but it's still best to avoid a direct high pressure spray at them. A gentle rinse should not cause any problems if allowed to dry thoroughly.
I cover pretty much everything in the engine room with Fluid Film / Boeshield / etc to avoid salt exposure. If I have to work on it it wipes away easily and then reapply afterwards.
DrFeelgood is offline
Old 05-26-2022 | 09:27 AM
Thanks for the input!
I was planning on doing it maybe once a month, not after each ride. We have hot weather here in summer (around 35C) and winters are quite mild as well as I am located in Malta. I will be using it for around 3 months so based on what you told me it shouldn't be an absolute necessity.
I will see how it goes and will take it on from there.
Ku310R is offline
Old 05-26-2022 | 09:57 AM
TomZ's Avatar
I used Gibbs on my stuff after a rinse. It worked really well especially on exposed aluminum (blower parts that were not painted, valve covers, exhaust). It’s easy to make a mess though; I’d apply sparingly.
TomZ is offline
Old 05-26-2022 | 12:33 PM
F-2 Speedy's Avatar
Are those exhaust tips pointed up ?
F-2 Speedy is offline
Old 05-26-2022 | 12:54 PM
B38
After washing, I take electric leaf blower and dry everything. Then drown it with WD 40 or something like that.
I run engine on garden house to flush salt out, then shut off, dove soap skwirt in hose at house. Then restart watch bubbles come out. Brings the pH to 7.6.
B38 is offline
Old 05-26-2022 | 03:28 PM
TomZ's Avatar
Same procedure - I use Dawn.
TomZ is offline
Old 05-26-2022 | 03:36 PM
I use a mix of dawn and salt a way to flush, and also spray the motors and bilge down almost every time, or the next day.
Wildman_grafix is offline
