525sc starter question
Old 06-09-2022 | 05:44 PM
Default 525sc starter question
I have what i understand to be a Gen VI 525SC engine in my boat based on the block casting number (10237297) and the 6 bolt timing chain cover etc. I have looked everywhere and have not been able to find the actual serial number anywhere. My starter went out at the beginning of last season and i have replaced it 2 or 3 times , once with a mercruiser starter and once or twice with a sierra. Each time the new starters have not lasted very long. Start making noise and then go out. I have researched and spoke to mercury many times trying to make sure i have the right part number. According to mercury reps and the applicable materials, all 525sc up to Gen V in 1996 used one starter (50-863007a1), and the Gen VI from part of 1996 on used another (8m8021116) . From what i can tell the later is a little heavier and higher torque. Both are active part numbers. Does anyone know what the actual difference is in those two starters and why a different one is recommended for the Gen VI? Are they interchangeable? Do i have enough information from the block casting number etc. to know i have a gen VI? I realize i could have had some junk starters or maybe a flywheel issue etc but i just want to make sure i have the right part before putting another one on. It is a real pain putting them on with the engine still in the boat. Lol. All help is appreciated. Thanks.
herm5000 is offline
Old 06-09-2022 | 06:07 PM
F-2 Speedy's Avatar
I run 525 long blocks and in my opinion there is nothing special about the starters or blocks, I bought 2 after market starters and they have worked perfect for 3 years you may have an alignment / shim issue or a ring gear problem
F-2 Speedy is offline
Old 06-09-2022 | 08:24 PM
I have a few tubs of parts from my 525sc’s. I am pretty sure at least one if not both of them had a shim on the starter. I will try to look tomorrow, if not it’ll be this weekend and see what I can find with the shins and starters.
tmmii is offline
Old 06-09-2022 | 10:32 PM
Thank you so much for your help! The Mercury rep mentioned I might need shims. Look forward to what you find.
herm5000 is offline
Old 06-12-2022 | 10:30 AM
very nice!
BoatKeep is offline
Old 06-12-2022 | 08:30 PM
sorry, running behind but it is still on my list.
tmmii is offline
Old 06-12-2022 | 10:47 PM
Thanks again. I appreciate it
herm5000 is offline
Old 06-13-2022 | 06:29 AM
SB
Low voltage kills starters too. #1 reason actually outside of being submersed.
Be it battery, connections, or cables.
SB is offline
Old 06-13-2022 | 08:32 AM
There is a real possibility you need to shim the starter. If a starter is not shimmed correctly it will lead to premature failure.
Precision is offline
