-   -   496 Mag Fuel Rail (https://www.offshoreonly.com/forums/general-boating-discussion/376482-496-mag-fuel-rail.html)
bmarinaccio 07-22-2022 04:47 PM
496 Mag Fuel Rail
I'm needing to replace my fuel rail... the GM factory fuel fitting on the fuel cooler line rusted to and through the fuel rail line. Merc PN 88169001 is obsolete. Spent the better part of the week calling everywhere to find one and no luck. While it's not my first choice, at this point, i'll take a good used one. Engine SN is OM650186.
Any suggestions?
Is it possible to have a fab shop replace the steel line between the regulator and the supply line and afix a permanent AN fitting? I can fab a new supply line with AN fittings.
I'm open to suggestions.
underpsi68 07-22-2022 06:41 PM
I wonder if that is a stock 8.1 chevy rail?
AllDodge 07-22-2022 08:02 PM
Looks like it GM part number
12575055 at GM parts direct
https://www.ebay.com/itm/164615713003
underpsi68 07-22-2022 08:12 PM
I posted wrong part
bmarinaccio 07-25-2022 08:02 AM
It is a GM rail... PN 12575055 but it's been on backorder for 9-10 months now. I've got used one locally which will work until i can get a new one. Might be time to upgrade the motor.
Keith Atlanta 07-25-2022 01:52 PM
Its the stock rail.
Another good place to look is eBay for good new old stock or somebody that has a new one on the shelf somewhere. Or, just a good used one.
Keith Atlanta 07-25-2022 01:54 PM
As far a welding, yes 100% I removed the stock garbage regulator and had someone braze either a 1/2 or 3/8 fitting on it to run an AN line to the Aeromotive regulator, fab a simple metal bracket and you are good.
Keith Atlanta 07-25-2022 01:56 PM
Heres a pic
https://cimg9.ibsrv.net/gimg/www.off...84f28977f8.jpg
