Bucket cooler to cool engine bay >
Old 08-08-2022 | 04:25 PM
Originally Posted by DallasBAJA
I participate in the LOTO shootout and it typically is hotter than Satan's butthole out there. I was wondering if utilizing something like this to not only cool myself off, but to also plumb a pvc pipe of some sort into the engine bay to assist with temps would be beneficial. I have been told to run with my engine hatched cracked open to get more air in for the race, but wondering if this would even do anything to help the engine and if so, how much could it actually help?
https://www.youtube.com/watch?v=HxSLbpAwibg
Get a cool shirt system.
hogie roll is offline
Old 08-08-2022 | 05:13 PM
DRAG's Avatar
Engine temp should be plenty cool so I assume you are wanting to get some cool air to the engines?
DRAG is offline
Old 08-08-2022 | 05:38 PM
Why not just remove the engine hatch all together? It will save weight and allow more fresh air around/into the engine. I don’t think any other form of boat racing besides offshore encloses the engine.
ttuton is offline
Old 08-08-2022 | 06:12 PM
My guess would be you need about 15,000 btus or more to make a difference in bilge with 2 big blocks in it.
Don`t know how many btus a bucket of ice is rated at but it`s not even close to what is needed. That ice would do nothing and be melted in no time.
You`d be better off putting on a small cooler and running fuel thru it. Cold fuel does way more than icing the intake .
That`s my plan anyway.
Old 08-08-2022 | 07:03 PM
SB
Originally Posted by Keith Atlanta
I would guess no, its cold, but not nearly enough CFM to do anything.
correct.
Many mild bbc’s consume 700+cfm of air. That’s nothing a bucket fan can feed. Would be better to source outside air just don’t restrict it doing so.
SB is offline
Old 08-08-2022 | 07:13 PM
I remember reading many years ago abt Lingenfelter using nitrous to chill an inter-cooler.on one of his Salt Flat runs. He didn't burn the nitrous, just used it to chill the intake charge. Pretty sure the eng used forced induction. Don't remember how much he gained.. Kind of an oddball/expensive option but for a short run in hot weather it works.
zz28zz is offline
Old 08-08-2022 | 08:35 PM
How about an automotive A/C compressor on one of the motors and stick the condenser between the intake plenum.
Isn't that how Dodge does it on the Hellcats?
techman is offline
Old 08-08-2022 | 09:42 PM
what make/ model of boat & what engine(s). ?
JaayTeee is offline
Old 08-09-2022 | 03:34 PM
Any gains would be negated by the load on the engine from the ac compressor and I think you meant evaporator .. condenser is the hot side. With unlimited cold water seems unnecessary.
ICDEDPPL is offline
Old 08-09-2022 | 04:20 PM
29 Fountain Fever with a single 525 EFI.
I am not having any over heating issues, was just curious if a little cooler air in the engine bay would do anything. Obviously much smarter people here have answered the question. This is a good discussion though.
DallasBAJA is offline
