Goal of hitting 80 in my 27' Fever >
Old 09-07-2022 | 01:19 PM
Indy's Avatar
Member #154
So many times the prop is messed up.
First thing I would do is try a good known 26 Hydro or maybe Bravo that has not been messed with.
That's where I'd start too. Sometimes they take so much cup out of the prop it loses bite. Maybe even a stock B28.
My best prop for my single Nordic was a stock B26 that was blueprinted/balanced, leading edge sharpened, and the in front of the cup he just etched/blasted that trailing 1" for some more bite.
Indy is offline
Old 09-07-2022 | 01:24 PM
SB
27 Fountain Fever prop help
Stock prop on 27 Fever
and many more.
that 540 have a ‘731 or similar cam ? 226/234 at .050” hydraulic roller ? How about old motor ?
SB is offline
Old 09-07-2022 | 01:32 PM
and many more.
Thanks for that link I’ll check it out. I searched earlier and found a couple threadsI went through.
cam is 241/253 615/630 not sure what the old cam was though.
540Fever is offline
Old 09-07-2022 | 01:36 PM
I like using this calculatore
if you have 1.65 gears then 26P/5800/72mph would put slip at about 17%
Propeller Calculator / Prop Calculator (rbbi.com)
PA.WOODCHUCK is offline
Old 09-07-2022 | 01:38 PM
I have a 1.5 gear so I’m over 20% depending on the calculator.
540Fever is offline
Old 09-07-2022 | 01:56 PM
SB
Interesting. But good ! Or should be anyway. Should have made more steam then your reported #'s. You have the real sheet to post ? Sometimes I can see some things on them. Tune issues / valvespring issues /etc...sometimes not Until we the sheet, I'll say engine should be propped to about 5400rpm. Maybe 5500.
Let's get more info, and have you run that with 34-35 total timing and .035" gapped plugs. Ck fuel psi wide open too. Might as well. We are diagnosing right ?
SB is offline
Old 09-07-2022 | 02:18 PM
Let's see if I can get this to work. My picture doesn't have the AR like in the full sheet, but hopefully this is enough. I can get a full view if needed.
A/F was around 11.7 > 12 through the full pull.
by https://www.flickr.com/photos/32474676@N02/, on Flickr
540Fever is offline
Old 09-07-2022 | 03:15 PM
I'm right about 3.5 on my trim which is parallel to the angle of the keel/hull. 4.5 seems to be the sweet spot, anymore I start to lose MPH and you can feel the boat getting loose.
Great points!
I think I am spoiled by the handling/stability at speed as my Formula 311 SR-1 has a flat (no step) bottom, weighs a ton (4 tons), has the Silent Thunder platform (drilled and hollowed out but still quite heavy) on the back of the boat, and Hardin Marine's Mayfair Full Hydraulic steering for dual Bravos.
Believe me, if it got loose my Wife would tell me immediately!
F14A water jet is offline
Old 09-07-2022 | 04:53 PM
DRAG's Avatar
First things first do a leakdown on the motor to make sure it’s healthy. I only say this because you said it felt bad first run and would not plane, and you had a fuel pressure issue. Make sure she isn’t hurt.
Timing shouldn’t be in question, run the timing where they made the power on the dyno. If you are 4 deg short of where it made best power there is a start
DRAG is offline
Old 09-07-2022 | 07:27 PM
I figured out it was just a bad fuel pressure gauge, but coupled with the engine bog it was a big concern at the time.
when I checked timing at 3200rpm my light was showing 40*. Shop said these DUI distributors aren’t great at maintaining timing at sustained rpm. He mentioned this to me when I picked up the boat and recommended I switch to MSD eventually.
I’m not opposed to that if I can appropriately control the timing. He said it peaked on his light at 38* around 4000 and then went back to 34* above 5000.
anyone had experience with these distributors?
Was looking at an MSD all in one with rev limiter built in. It’s the 86306. https://www.holley.com/products/igni...rs/parts/83606
540Fever is offline
