Towing with gas trucks
Old 11-22-2022 | 04:09 PM
  #61
Originally Posted by 540Fever
For those with 25-30 footers towing with half tons… I have a 6.2 1500 that pulls my 27’ Fountain. It does pretty good from a suspension perspective, but when I get into areas with rolling hills, the motor is working!
I’ve looked into diesels, but I just don’t want any to pay the premium. I like my half ton and if it had a little more juice, it would tow just fine.
Seems heat is the issue with most gas/turbo tow setups. Has anyone done a low comp setup with a small turbo for a tow application?
540 Fever I’m in the exact situation and looking now too. I have a 2015 1500 6.2 8 speed that I bought new. It does a good job with my 26zx and of course a diesel would be vastly better, but I’m probably going to buy another 6.2 with the 10 speed to replace it. As far as high RPM on hills I look at it this way I run a 23 year old big block all day from 3k to 5k so I’m not hurting that new tech motor down shifting it.
Donzi1979 is offline
Old 11-22-2022 | 04:13 PM
  #62
Originally Posted by SabrToothSqrl
not sure how I am yelling at clouds when there are plenty of real world tests with the electric trucks and they only made it 100 miles towing 6500 pounds or less and only on flat ground. add in the hills and you will be lucky to get 60 or 70 miles on a full charge. again not my opinion but actual tests that have been documented
compedgemarine is offline
Old 11-22-2022 | 05:17 PM
  #63
SB
Yup the latest lightning electric one was really not good.
SB is offline
Old 11-22-2022 | 06:09 PM
  #64
Donzi,
Agreed. Keep it in its happy RPM range, and the engine will be fine. That's literally what the transmission is for. I hardly ever see anything over 4000 RPM with my 5.3.
Thanks. Brad.
(937)545-8991
Brad Christy is offline
Old 11-22-2022 | 06:43 PM
  #65
Fair enough. I read that is it a disappointing towing range so far. I had hoped it was farther.
https://www.motortrend.com/reviews/f...k-towing-test/
We will get there, but yeah, today it's just not far enough to be practically used for moving boats around.
SabrToothSqrl is offline
Old 11-22-2022 | 09:32 PM
  #66
Go big or go home.
14 liters and 535 horse with 1800 lbs torque and a 13 speed will pull 25-30 thousand like it’s not even back there up anything but the steepest grade.
Pull 10 mpg all day empty 8 lightly loaded. Easy to work on and parts are cheap.
tommymonza is offline
Old 11-23-2022 | 05:15 AM
  #67
It’s funny that in 1999 you couldn’t buy a diesel pick up that makes the power of todays gas engines. Guys didn’t use peterbuilts to haul their top guns to poker runs.
Unlimited jd is offline
Old 11-23-2022 | 05:16 AM
  #68
Originally Posted by tommymonza
Go big or go home.
pretty much what you need to haul anything more than a sweet 16 donzi. 🤣
Old 11-23-2022 | 06:01 AM
  #69
Quinlan's Avatar
I agree. How can the get even close to 100 miles towing anything. Now 0-60 will be a riot!!
Quinlan is offline
Old 11-23-2022 | 06:05 AM
  #70
Quinlan's Avatar
as he said- GO big or Go home.
Fuel milage???? if we cared we Wouldn't be in Boating
Quinlan is offline
