I'm w/ the tune posts and to add,whats the fuel pressure?
It also seems there is no tstat as it doesn’t get up to temp. Doing some other reading this could pose a problem as well 🤷♂️
You have a pic of frt of your engine so we can see what cooling system it has ?
Originally Posted by SB
(Post 4869078)
(Post 4869078)
https://cimg1.ibsrv.net/gimg/www.off...2e6c97df7.jpeg |
Originally Posted by liberator221
(Post 4868810)
Have you considered an ignition system to get multi spark at idle? MSD,Accell, or whatever you like. We’re ECMs retuned?
Originally Posted by CaptainChazz
(Post 4869074)
How hot is it getting, ECU still could be adjusting fuel for cold engine? |
Originally Posted by PA.WOODCHUCK
(Post 4869335)
previous Owner claims there are thermostats in there |
whole lot going on here but my first guess it that it had ProChargers on it that are now gone and if it was tuned that is what it was setup for. you have a vacuum hose with a screw in it, where is that going? it does not have a thermostat with that setup so it will struggle to make temp especially with all that fuel running thru it. not sure if that ecm is looking for water temp to go adjust it but odds are that alot was changed before you got it and they just made sure it would start so they could sell.
Originally Posted by compedgemarine
(Post 4869337)
| All times are GMT -5. The time now is 10:38 AM. |
