-   -   Best fender covers for painted boats (https://www.offshoreonly.com/forums/general-boating-discussion/379795-best-fender-covers-painted-boats.html)
thisistank 04-18-2026 02:49 PM
Originally Posted by Liveaboard (Post 4946097)
I appreciate it—I genuinely love them. And like I mentioned, I’m not affiliated with the company at all. I’ve just shared my experience a few times, and it’s funny how saying something positive about a small business can set people off.
There are bigger things to get worked up about, and I doubt most of those comments would be said face-to-face. Not everything is a sales pitch. Also, what happened to be able to recommend companies on a forum like this without being accused of being the owner? Isn’t that what a blog like this is for? Either way, I’m going to keep talking about my fender covers because they’ve been great, and I have no problem recommending the team at Flexifabrics—they’ve done an awesome job.
Here’s the link again for all of the haters: Flexifabrics.com!
all good. I agree. There’s many on this particular site that are gun shy about new posters because over the years there’s been a lot of scammers. Many around have been on here for 20 plus years and it’s line a tight but family so they’re protective.
like i said, all good. The covers look great. 👍
Liveaboard 04-18-2026 03:21 PM
Originally Posted by JPEROG (Post 4946110)
We now use nothing but BRIS inflatable bumpers and they offer neoprene covers that work great. Paint is WAY too expensive not to have them. They are available on Amazon and are very light weight-highly recommend them.
Joe
That’s exactly right, my gel coat was $20k and I refuse to listen to anyone saying no fender covers are necessary. I saw what my polyform fenders did to my old gel coat and it wasn’t pretty. These covers from Flexifabrics.com are 5mm neoprene with a soft polyester lamination, super thick and soft.
Padraig 04-18-2026 04:34 PM
As a long time diver, I can tell you that sand has a real affinity to neoprene. It is one of the last things I would use as a fender cover
Padraig
Liveaboard 04-18-2026 05:17 PM
Padraig
I get what you’re saying, but I think there’s a bit of a misconception here—and I’m a diver myself, so I understand the concern. Boats typically aren’t docking in sandy environments to begin with, and these covers are polyester-laminated on the outside—they don’t trap sand at all. In fact, debris tends to brush right off the surface. The real issue with debris buildup is with fleece-style covers, which actually hold onto dirt and grit much more.
With Flexifabrics covers, the neoprene is underneath that outer layer and acts as a 5mm protective cushion, so it’s not even exposed in the way you’re describing. That cushioning is exactly what helps protect gelcoat from scuffs and impact.
Also, neoprene is used in wetsuits for a reason—it holds up extremely well in harsh saltwater environments, resists wear, and is easy to rinse clean. There’s also a reason most yacht fender covers are constructed using neoprene (often around 2mm to save on cost), and why companies like Body Glove consistently choose neoprene—it performs exceptionally well in sun and saltwater, especially when it’s properly laminated with a polyester outer layer like these.
From a practical standpoint:
-Smooth outer surface = less friction and less debris retention
-Cushioned core = better protection than thin fabric covers
-Water-resistant materials = no soaking or heavy, waterlogged covers
-Easy to clean = quick rinse vs. holding grime
So the idea that neoprene-based covers are somehow worse because they “trap sand” doesn’t really line up with how these are actually constructed or used. Flexifabrics has clearly put thought into the design, and it shows in real-world use.
XSNSX 04-19-2026 02:00 PM
Claims not to be affiliated with the company but takes a defensive posture, touts the benefits and posts multiple links to the company.
Smarty 04-19-2026 02:19 PM
After reading the posts in this thread I decided to go to Copilot to find out what AI has to say on this topic and here was the answer:
“For most boaters, polyester is the best overall choice because it lasts longer, resists UV, and handles abrasion better. This is especially true if your boat stays in a marina or sees regular docking.
Choose fleece if:
* You want the softest possible contact surface
* You dock infrequently
* You’re protecting a freshly polished or delicate hull finish
Choose polyester if:
* You want maximum durability
* Your fenders see heavy use
* You want better UV and water resistance
* You prefer a tighter, cleaner look over time”
Then AI provide this summary about Neoprene, “Neoprene is the premium, performance‑oriented option for boat fender covers. It sits between fleece and polyester in softness, but far exceeds both in fit, durability, and stability. If you want the tightest, cleanest, most secure cover that won’t slide, neoprene is the top choice.”
ICDEDPPL 04-19-2026 10:39 PM
Those fleece ones are the worst, always sopping wet , hold water , look like crap after a short time. Those were the biggest waste of money.
If someone has black fenders and with no covers they can`t tie up to me. They`ve always left a bunch of black specks that have to be buffed out .
