That sounds like a perfect sleeper. Was going that route with my previous boat until it burned to the ground while in storage
Yes it’s always a worry with the heater in the engine compartment, it must have sucked immensely to have that happen. I have a heater in the Bayliner engine compartment with the 496 and a heater in the 1977 30ft scarab that I am restoring/restomod/butchering, finally doing the first 388 Sbc this week
Originally Posted by Padraig
(Post 4915145)
Looks like no one can or will answer your question.
Padraig |
Good on you, I am about to do my two oil change for winter layup, also switching out v belts for serpentine belt, I switched out my Holley carb this summer and installed my old commander 950 Efi system, I forgot how much I like Efi, did fuel only and will put in the computer controlled timing in spring. Having fuel control is so nice and good cold start. Did you switch to the K&N gold oil filters they filter down to 10 microns most of the other filters are 20 microns and larger.
Originally Posted by 496blower
(Post 4937641)
Where did you get the serpentine kit from? |
Didn’t get a kit just ordered and 7 inch crank pulley and 5 inch water pump pulley from March performance I had a serpentine alternator pulley in my pile of pullies, just gonna install and use the March alternator bracket to tighten it. Gonna be a bit tricky install as I use the Volvo crank mounted water pump.
| All times are GMT -5. The time now is 02:55 AM. |
