-   -   Sea strainers leaking (https://www.offshoreonly.com/forums/general-boating-discussion/381283-sea-strainers-leaking.html)
way2fast 12-22-2023 12:38 AM
My sea strainers are dripping into bilge. Is there anything I can do while the boat is in the Water
jeff32 12-22-2023 06:45 AM
if you dont have ball valve before strainer... no!
or you can try it by blocking the hose with a rag but that is a more risky way to do it!
Sydwayz 12-22-2023 07:05 AM
Most of the time, there should be a ball valve between the pickup and the sea strainer. Else, what good is the SS if you can't stop and open it up to clean it?
Close them off, and open them up. Depending on which SS you have, you may have a cracked lid, or a bad seal/o-ring that might need replaced. Pics would help.
way2fast 12-24-2023 01:08 AM
https://cimg1.ibsrv.net/gimg/www.off...ebb932208.jpeg
https://cimg3.ibsrv.net/gimg/www.off...98f8c2a20.jpeg
Not sure if this photo displays it or not but sea water is coming in and dripping off the bottom of them
bajaman 12-24-2023 05:53 AM
damn...looks like more than a 'drip' to me! And yeah..I guess I always thought one could close an up-stream valve and shut off the water so one could clean them as necessary, at sea. Guess I have been wrong all these years.
Helmwurst 12-24-2023 09:41 AM
That green shiit on there is bad. You have a leaky ground somewhere and the bottom is probably corroded.
105Fountain 12-24-2023 09:50 AM
Have same exact strainers in shed! I removed them because kept dropping wing nuts in bilge on old boat:pray: Glass or bottom seal cracked just a guess?Good luck merry x mas
ICDEDPPL 12-24-2023 12:53 PM
Is that a pic from The Titanic?
