-   -   Dual Power Steering pumps? (https://www.offshoreonly.com/forums/general-boating-discussion/382119-dual-power-steering-pumps.html)
Swamplizard 04-10-2024 10:13 AM
Did a repower to Merc 496s and they each have a PS pump and reservoir. Since the motors I replaced had one spinning each way only one engine is plumbed to drive the PS.
Can I have both pumps running and connected so I have power steering regardless of which engine is running? I like running one engine when trolling/fishing.
Thanks Swampy
Wildman_grafix 04-10-2024 11:27 AM
Yes, my Fountain has pumps on both motors, pretty nice. There is a "Compensating valve" to do it? Think that is what it's called.
Its the red block below the filter.
Your motors go the same way now?
https://cimg2.ibsrv.net/gimg/www.off...21e17d7baa.jpg
Ed 04-10-2024 11:43 AM
dual p.s. pumps...
simple install lizard. even you can do it. called a proportioning valve. fountain was about the only company that did it.
Swamplizard 04-10-2024 01:25 PM
Thanks guys - yes both motors go the same way
VetteLT193 04-10-2024 05:51 PM
Latham sells it, I wanted to do this on my last boat and never got to it
Boatlesss 04-10-2024 08:07 PM
plumb each pump into a check valve so that one pump cannot backfeed the other pump when one engine is not running. then T the lines together going to your helm
Griff 04-11-2024 12:28 AM
Imco sells what need need as well.
Pro1 04-11-2024 06:54 AM
I have an Imco for sale for $250 if anyone needs one
TexomaPowerboater 04-11-2024 01:13 PM
I had my 28 Saber twin engine converted to dual steering pumps. Can call Imco and they will get you setup. Cost was like $4K not including the labor, but that included all new hydraulic lines for both pumps.
