Originally Posted by Tartilla
(Post 4898035)
Doesn't cupping add dynamic pitch?
You`re almost to 100MPH I know how that is tryuing to get to that third digit! lol |
Originally Posted by SecondWind
(Post 4898236)
I think it depends on who you ask. Ask someone with a yacht and it's a runabout. Ask someone in a Jon Boat and they'll probably give you the bird.
Originally Posted by ICDEDPPL
(Post 4898263)
100%. I had a 27pitch prop I couldn`t get past 4500 because of the crazy cup. Usually ran 29`s to 6200.
You`re almost to 100MPH I know how that is tryuing to get to that third digit! lol I’m fairly confident I’m there in ideal conditions. Give me a slight chop and a tailwind and the speedo is going to run out of numbers. I’d rather Mother Nature help me from here and not my check book😊 Rob |
Originally Posted by Knot 4 Me
(Post 4898280)
The blow boaters and perch jerkers have to love you on Clinton Lake. :lolhit:
(Post 4898286)
I didn’t see many of them waving at me🤣
(Post 4898285)
Dan,
(Post 4899373)
I have a 98mph boat! I've now performed several pulls in different water conditions and I always get stuck at 98. I'm not complaining but was assuming conditions would solve my quest, not so! No way around it, you pay for performance:ernaehrung004:
Are you spinning your props in or out?
I have a set of Hydromotive 4 blades labbed by BBlades to 27 1/2 or 29 1/2 if anyone is interested. These were 4 mph faster on the Velocity compared to Bravo 1 standard 30’s. Bravos were 88mph and Hydro 92mph WFO. From my experience the Hydro’s run better above 4,500 rpm with Bravo’s being much better from idle to a fast cruise speed at least on the pad bottom. |
Originally Posted by Powerquest230
(Post 4899385)
You might try swapping your props to see if spinning in will get that third digit. iIRC spinning in will give more stern lift and loosen things up a little.
For daily use on the Velocity the Bravos win- much easier planing and low speed handling. |
| All times are GMT -5. The time now is 09:58 PM. |
