where to find factory prop info? >
Old 11-16-2024 | 04:31 PM
Originally Posted by Danimal182
I have a friend with a set of bravo 1 28s. Ill look for a set of hydros to try. I havent taken this boat out yet, just got it running straight. will be taking it out Monday after work or whatever day next week looks best for weather.
Danimal- give the Bravo 1 28’s a try as they should be pretty close. I also have a 320 and for overall use prefer the Bravo 1s over the Hydromotive. I have several sets of props and the Bravo’s are a couple mph slower than my Hydro IV’s but they are much better in handling, planing, and cruising.
Powerquest230 is offline
Old 11-16-2024 | 04:56 PM
Originally Posted by underpsi68
I would think a set of 28s since a 280 with single 496 runs a 26.
What speed and rpm are you running with the 280?
HuskerPerformance is offline
Old 11-16-2024 | 07:01 PM
Ran 68 at 5000ish (on tach) any day of the week. Would run 70 in good conditions. Best run was 74 with light fuel.
underpsi68 is offline
Old 11-16-2024 | 11:35 PM
looks like your hull with 26 @5000 at 74 with 1.5 gear ratio you have 10% slip. I don’t think the 320 with 496s will do well with 28s. 26s or have it labbed to a 27 would be what I would run. hydromotives get good bite and low slip numbers Best of luck
