Portable generators.
#41
I thought about that too.
Thats a nice little spot ... I wasn`t sure if I could pull the cord with it tucked in there .
#42
#43
I doubt this would be practical if at all possible, but it's just another option you might not have thought of.
https://www.milwaukeetool.com/Products/2845-20
#44
Love Milwaukee stuff thou.
#45
#46
I recall that as well. Think it was a 40 roadster grandsport center had for sale a few months ago.
#47
Why not put a couple big Battle Born batteries as start batteries and a decent sized inverter . Their 275 amps each and can be pulled down 80% before they will shut off.
Little more money but professional and safe , warrantied 10 years you could run the A/C anytime of the day or all day as well as an electric freezer/ ice maker / frig
#48
Xlint 89 , I would guess four 12.0 batteries would last maybe an hour. At $250/ battery .. I do use em for work but only have a couple of the 12,0`s
Tommy $$$
I bought a Predator 2000 , we`ll see how it all works out .
Tommy $$$
#50
May want to consider a magnetic dipstick and /or drain plug since these little engines have no oil filter.
On my Champion 2500W inverters, I installed a magnetic dipstick before the first start so I could monitor break-in. Most generator manuals say to do a 5 hr break-in switching from unloaded up to 1/2 (or 3/4) load periodically to seat the rings properly. Change the oil after the first 5 hrs.
If you're OCD like me, replace oil after first hr then again at 5 hrs runtime and strain the old oil to look for chunkies. Break-in should be done using dino oil (some generators come with a qt of break-in oil) and some folks switch to syn oil after break-in. Personally, I just put dino oil back in and plan on 25-50 hr oil change intervals depending on conditions.
They make aftermarket hour meters with maint reminders and tachometer. They are cheap and really help keeping up with servicing.
