ATTN, Troubleshooting gurus...head scratcher... >
Old 08-22-2025 | 02:27 PM
F-2 Speedy's Avatar
Id pull the pickups and see if they have those sock thingies on them, and replace the 29 yr old fuel lines
F-2 Speedy is offline
Old 08-22-2025 | 03:31 PM
SB
^^^^very well could be that stuff.
Have worked on 2 boats that it was the carb’s. 1 was about 5 min’s cruise speed. Good cleaning, full rebuild kit with needle and seats, wallah…,I thought ignition but nope…..
psst: not saying this is your problem. Just throwing more on the table.
SB is offline
Old 08-22-2025 | 03:40 PM
if it has quadrajet carburator, check the stone filter in the carburator fuel inlet
SammyJ is offline
Old 08-22-2025 | 06:00 PM
The re-start symptoms sounds like a flooded eng; "gotta hold throttle wide open, runs rough at first then clears up". Do you see black smoke out the exhaust when restarting after one of these episodes? If you have a fuel press gauge, see if it holds press for a while after eng shuts off and look down the throat of the carb if fuel press falls quickly. Could also look for liquid in the hose that connects the diaphragm cavity of the fuel pump to a port on the carb (if equipped).
zz28zz is offline
Old 08-22-2025 | 09:16 PM
phughes69's Avatar
Ive had my fair share of problems just like this. Ill repeate what others have said
  • check fuel filter in carb if Q-jet
  • make sure fiklter is installed correctly in carb. One way it will starve the carb for fuel the other way is good
  • when it gets restarted see if the exhaust is black- Qjets were know for having leaking primary jet wells
  • Check that the choke is fully open
  • if you can check that the fuel pickup isnt partianlly clogged. The screen in the end are pretty small
  • vapor lock- check temperature of fuel pump with a infra red temp gun
  • bad fuel pump- if you ever used auto gas, the diaphram can get hard and wont pump as well
  • If possible fuel a fuel line from a gas can to fuel pump to bypass rubber line.
  • Check grounds for distributor
  • When it does shut down, take spark arrestor off both engines, compare accelerator pump shot between both engines
It sounds like something temperature related. since this is the port engine the fuel pump is stuck between two engine and may not get enough air flow.
I had a similar problem, thought it was bad fuel pump, installed a electric pump, still had problem, replaced lines, problem seemed to go away, but it had a stumble once, pulled fuel pump apart and found the diaphram was hard, rebuilt fuel pump, pulled tank pickups, screens were 1/3 plugged but fuel outlet was 1/4 npt (WTF) replaced pickup with custom 3/8 stainless with no screens and outlets are -8an now.
phughes69 is offline
Old 08-23-2025 | 09:04 PM
I pulled the rubber fuel line, it looks ok, ran a wire through its length no issues, cut it in two places, looks fine, pliable...I put a fuel bulb inline, at the filter inlet. at 3200 rpm the bulb is stable no contraction, I can't pull the inlet out of the tank, but blew into it, no restriction. the clear tube on the pump is empty,
I'm leaning to an issue with the float flooding the engine, because of the having to hold it wide open to clear and run...it has a weber 9780S 4 barrel, I'm not familiar with it, will put up another post for advice on it....
Zekester is offline
Old 08-24-2025 | 10:49 PM
If it have raw water pump integrated fuel pump, check it if cam or follower are worn out. Then it won’t pump enough fuel at higher load.
ksalmine is offline
Old 08-25-2025 | 03:48 PM
pulled carb off, going to clean and rebuild,
Zekester is offline
Old 09-16-2025 | 11:13 AM
Found it, took carb apart noticed floats were set way too high, put pressure gauge on fuel line at carb, 9 psi at idle over 15 at 2500, off scale at 3300, checked gauge on my 7.4 litre, 6 psi all day...pulled (mechanical) pump, housing full of fuel not gear oil, replaced fuel pump, runs perfect. fuel way over pressure, gets by needle, flooded it....
Zekester is offline
