hynautic external steering? >
Old 12-17-2002 | 12:13 AM
puder's Avatar
speel chekk this fokker!
Default hynautic external steering?
i can get a hynautic external steering setup cheap. BUT aparently its not stainless. Does anyone know what its made out of? will it hold up in salt water?
Pardon me, while I whip this out!
puder is offline
Old 12-17-2002 | 12:18 AM
Ron P's Avatar
Enjoy the show
That's not what you want. You know what you need.
Ron P is offline
Old 12-17-2002 | 05:38 AM
Audiofn's Avatar
Charter Member #232
Everyone that I have talked to that has the hynautic system is real happy with it. They work fine, just do not look as nice as a stainless set up. I think they brass plate them or something.
Jon
Put your best foot forward!
Audiofn is offline
Old 12-17-2002 | 06:30 AM
Mbam's Avatar
Offshoreonly Advertiser
Puder, way back Hynautic brass cylinders were used with Char Lyn helms for full power hyrdraulic steering, there was not much else around. Latham started to manufacture his own cylinders, first out of brass then stainless. In fact I had some stainless cylinders made around 1979 and Latham bought a couple. THey were not much to look at, but at least they were stainless. Then Then the other guys jumped on board. However the bulk of the Hynautic systems I have seen use aluminum cylinders with manual helms. The brass one has 4 external tie rods that hold the ends on the cylinder.
Mbam is offline
Old 12-17-2002 | 07:41 AM
The cylinders are nickel plated brass. They hold up fine to salt water. The rebuild kits are still available. Most used a 14 piston helm so the steering is a little stiff.
mercury is offline
Old 12-17-2002 | 08:32 AM
Airpacker's Avatar
a friend has it on his outboard velocity 30,works well but a real ***** around docks,stiff,slow and 9 million cranks lock to lock.
Airpacker is offline
Old 12-17-2002 | 08:36 AM
New or used? Do you want just cylinders or the whole setup?
I'm not sure if they make a power assisted helm.
Gary
Gary Anderson is offline
Old 12-17-2002 | 08:56 AM
Jeff
dude, why dick around with that old school stuff. Quit half-steppin'
Old 12-17-2002 | 09:16 AM
AC
My brother in-law has hynautic external steering setup on his 1981 28 SS Cigarette. It's been on the boat for about 15 years and is holding up fine (used in salt & fresh water). The steering is not power assist - a little hard to turn and it takes many turns of the wheel to turn the boat. It’s great for high speed but not so good around the docks. If you do not have twins - don't even think about it.
AC
AC is offline
Old 12-17-2002 | 11:47 AM
puder's Avatar
its a single ram tie in system. and the price is right
puder is offline
