Like Tree0Likes
Painting Fiberglass
Old 01-06-2003, 11:14 AM
mr_velocity's Avatar
Default Painting Fiberglass
It's time to put a coat of paint onto the old fiberglass dock box. It's just chalking too much and I really don't want to be out there waxing it. I want the paint to be maintenance free for a long time so I was thinking of a polyurathane, correct me if I'm wrong. Will a single part poly like Interlux hold up to the abuse or do I need to go with a two part paint?
mr_velocity is offline
Old 01-06-2003, 03:02 PM
Not one person has an opinion on painting fiberglass? This is supposed to be the site of unparralled knowledge.
Old 01-06-2003, 03:08 PM
searace
To do it right, for that application, i would use URO prime by dupont, then paint with IMRON 333 series polyurithane. Its cheap imron, but make sure you use the accellerator.
Hope this helps
HAWK POWER
www.searace.com
Old 01-06-2003, 04:11 PM
Thanks,
Never thought about IMRON for this application. I've used it on my drives and tabs though.
Old 01-06-2003, 04:18 PM
Reindl Powerboats's Avatar
My Boats: Reindl 28 Vamp, Reindl One Design
You could 320 it, paint it with any automotive paint and then clear it to look really sharp. If it is a duarbility item, we use awlgrip.
Reindl Powerboats is offline
Old 01-06-2003, 08:23 PM
572scarab
Sand with 320 single stage urathane it and be done with it. If you use a solid color you will not ever be able to tell it not base coat clear coat! Just my 2 cents as i would rather be boatin than painting! Unless you live in this F#*%ing snow S%$# cold A## state called OHIO!!!!!
Old 01-06-2003, 09:45 PM
I was thinking that a two part would be better. Naturally not having to prime would be best since I just told a friend what I was doing to mine and he wants me to do 40 at his condo. Now the quality and durability of the job is even more important.
Old 01-07-2003, 07:46 PM
572scarab
Single stage is a 2 part 4:1:10% 4 parts paint. 1part catalist 10% thinner. There is no need to prime just scuff and shot! unless fiberglass stands are starting to show.alot less time to do it this way than to base coat clear
gripit
Cigarette
8
03-31-2006 09:05 AM
jamieslib
Fiberglass and Paint
2
02-23-2006 10:59 PM
CAPTAIN CHUCK
16
03-18-2005 06:31 PM
olemissalum
02-17-2004 11:02 PM
patrick22309
07-21-2003 06:00 PM
